Date/Time: Mon, 06 May 2024 09:27:28 +0000
use of sierra chart on two PCs
View Count: 831
[2015-11-27 06:15:50] |
User737065 - Posts: 23 |
Hello, it is possible for me to use sierra chart on two PCs simultaneously? Thank you, regards |
[2015-11-27 06:56:22] |
Yes. This is no problem.
[2015-12-01 07:42:03] |
User742717 Mike - Posts: 86 |
it doesn't work for me :/
[2015-12-01 07:57:59] |
You must have a direct paid Sierra Chart account to be able to use Sierra Chart on more than one system at a time.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-02 09:40:02
