Date/Time: Sun, 19 May 2024 12:36:28 +0000
Currenex FIX conection error " EC1- Replaced by new session" connect/disconnect
View Count: 1674
[2015-11-26 15:11:09] |
User368248 - Posts: 46 |
Hello. I am configuring Currenex FIX access, I can connected but after 1 minute receive a disconection message , can you help me on this? Thanks in advance. Currenex: Connecting. | 2015-11-26 08:08:32 Connecting to market data server: pret-fix-ssl.currenex.com:443 | 2015-11-26 08:08:32 Currenex FIX Data socket (0) | Resolved address pret-fix-ssl.currenex.com to IP 204.16.181.31 | 2015-11-26 08:08:32 Currenex FIX Data socket (34) | Connected. | 2015-11-26 08:08:32 Currenex FIX Data socket (34) | Starting TLS 1.0 connection. | 2015-11-26 08:08:32 Currenex FIX Data socket (34) | SSL connection established. | 2015-11-26 08:08:32 Currenex FIX Data: Sending the Logon message. | 2015-11-26 08:08:32 Currenex FIX Data: Connected. | 2015-11-26 08:08:34 Currenex FIX Data - Trading Session ID: 0. Status: Open | 2015-11-26 08:08:34 Connecting to trade server: pret-fix-ssl.currenex.com:443 | 2015-11-26 08:08:34 Currenex FIX Trading socket (0) | Resolved address pret-fix-ssl.currenex.com to IP 204.16.181.31 | 2015-11-26 08:08:34 Currenex FIX Trading socket (35) | Connected. | 2015-11-26 08:08:34 Currenex FIX Trading socket (35) | Starting TLS 1.0 connection. | 2015-11-26 08:08:34 Currenex FIX Trading socket (35) | SSL connection established. | 2015-11-26 08:08:34 Currenex FIX Trading: Sending the Logon message. | 2015-11-26 08:08:34 Currenex FIX Trading - Trading Session ID: 0. Status: Open | 2015-11-26 08:08:35 Currenex | Connected to data and trading server. | 2015-11-26 08:08:35 NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2015-11-26 08:08:35 Currenex | Starting real-time market data updates for: EURUSD. ID: 1 | 2015-11-26 08:08:36 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2015-11-26 08:08:36 HD Request # 5 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: cnx | 2015-11-26 08:08:36 HD Request # 5 | Download start Date-Time: 2015-11-26 08:07:58.000 | 2015-11-26 08:08:36 HD Request # 5 | Using server: ds5.sierracharts.com port 10149 | 2015-11-26 08:08:36 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-11-26 08:08:36 Socket (36) | Connected. | 2015-11-26 08:08:36 HD Request # 5 | Sending historical data logon request message. | 2015-11-26 08:08:36 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2015-11-26 08:07:58. Record interval: 0. Symbol: EURUSD | 2015-11-26 08:08:36 Socket (36) | Shutdown and closed. | 2015-11-26 08:08:36 The network socket for historical data has been closed. | 2015-11-26 08:08:36 HD Request # 5 | Error downloading historical Intraday data for EURUSD. Historical data file not available for symbol. | 2015-11-26 08:08:36 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EURUSD | 2015-11-26 08:08:36 HD Request # 5 | Intraday download COMPLETE for EURUSD. Completion time: 0s. Unique request ID: 4 | 2015-11-26 08:08:36 Removed historical data download ID 4 | 2015-11-26 08:08:36 Real-time Intraday chart data file updates started for EURUSD | 2015-11-26 08:08:36 Currenex FIX Data: Received a Logout message. Text = EC1 - Replaced by new session | 2015-11-26 08:08:57 Currenex FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-11-26 08:08:57 Currenex FIX Data socket (34) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-26 08:08:57 Currenex FIX Data socket (34) | SSL has been shut down. | 2015-11-26 08:08:57 Currenex FIX Data socket (34) | SSL object has been freed. SSL state is now disconnected. | 2015-11-26 08:08:57 Currenex FIX Data socket (34) | Shutdown and closed. | 2015-11-26 08:08:57 Currenex FIX Data: Logged out and disconnected. | 2015-11-26 08:08:57 Connection to the external service has been lost. | 2015-11-26 08:08:57 Currenex FIX Trading: DisconnectFIX called. | 2015-11-26 08:08:57 Currenex FIX Trading: Sending a Logout message. | 2015-11-26 08:08:57 Currenex FIX Data: DisconnectFIX called. | 2015-11-26 08:08:57 Disconnected from Currenex. | 2015-11-26 08:08:57 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-26 08:08:57 Currenex FIX Trading: Received a Logout message. | 2015-11-26 08:08:57 Currenex FIX Trading socket (35) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-26 08:08:57 Currenex FIX Trading socket (35) | SSL has been shut down. | 2015-11-26 08:08:57 Currenex FIX Trading socket (35) | SSL object has been freed. SSL state is now disconnected. | 2015-11-26 08:08:57 Currenex FIX Trading socket (35) | Shutdown and closed. | 2015-11-26 08:08:57 Currenex FIX Trading: Logged out and disconnected. | 2015-11-26 08:08:57 |
[2015-11-26 20:07:08] |
The connection is successful to Currenex: Currenex FIX Trading - Trading Session ID: 0. Status: Open | 2015-11-26 08:08:35 Currenex | Connected to data and trading server. | 2015-11-26 08:08:35 Currenex is logging the connection out and giving this message: Currenex FIX Data: Received a Logout message. Text = EC1 - Replaced by new session | 2015-11-26 08:08:57 We do not specifically know what is meant by "EC1 - Replaced by new session". Please ask Currenex. Maybe there is another connection using the same FIX connection details. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-26 20:07:22
[2015-12-24 10:12:44] |
batman_ - Posts: 190 |
Does SC still actively support Currenex real time data feed FIX connection? I would like to use a reliable forex data feed that can offers best bid and best ask volume & tick. Please advice accordingly. TQ. |
[2015-12-24 10:56:57] |
Yes Currenex at this time is fully supported.
[2015-12-29 12:38:51] |
Would there be a write up documentation for Currenex real time connection in Data/Trade Service?
[2015-12-30 00:37:56] |
We will be working on documentation later this evening for this.
