Date/Time: Sat, 04 May 2024 22:51:58 +0000
chart start date displayed on the LHS
View Count: 741
[2015-11-26 10:55:48] |
User553714 - Posts: 184 |
Hi, I have some old txt data that loads ok but displays the start date (oldest date in the data series) on the RHS of the chart instead of the LHS of the chart. When you view the txt files the newest ticks are at the top (D, O, H, L, C, V) and the oldest tick is at the bottom of the files. My question; is there an easy way to flip charts plotted this way so that the newest data is displayed on the RHS of the chart as you would expect. A software fix would be much easier than me writing code to reverse the way the data is stored in the txt/csv files. Sample file data below; 2015-11-20,79.35,80.23,78.91,79.83,2950800 2015-11-19,78.59,79.18,78.16,79.14,3267700 2015-11-18,76.47,78.25,76.38,77.84,3150700 2015-11-17,75.99,77.07,75.58,77.07,2930800 2015-11-16,74.64,75.52,74.63,74.78,2114200 2015-11-13,75.66,76.19,75.03,75.76,2885000 2015-11-12,75.60,77.69,75.52,77.40,2560500 2015-11-11,74.85,76.29,74.85,76.00,2720000 Thanks for your help & Regards |
[2015-11-26 11:16:47] |
You need to reverse the order. We recommend loading the data into a spreadsheet program, and sorting the rows so they are ascending timewise.
