Date/Time: Mon, 29 Apr 2024 03:23:59 +0000
coloring cut face between study curve and horizontal line
View Count: 823
[2015-11-26 07:54:50] |
User166870 - Posts: 13 |
How to color the cut face between a study curve (e.g. RSI) and a horizontal line (e.g. 70%). Thanks Hannes Date Time Of Last Edit: 2015-11-26 07:56:40
[2015-11-26 08:14:44] |
We are not understanding this. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-26 09:33:46] |
look here please : http://www.sierrachart.com/image.php?l=144853022094.png |
[2015-11-27 18:24:28] |
There is no straightforward support in Sierra Chart to fill those areas. The closest that is available is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#FillingArea Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
