Date/Time: Mon, 06 May 2024 12:16:42 +0000
Organizing buttons (New changes)
View Count: 667
[2015-11-26 01:32:59] |
Mike_S - Posts: 42 |
We used to be able to change the names of buttons under this list. (See attached chart) Now that everything has reverted back to "custom text drawing #" it is near impossible to organize my list of buttons on the bar shown in my picture because I don't know which button belongs to which CTD# anymore. I have 50+ text and drawing buttons and have to go 1 by 1 like this... It will take forever to do it like this. The "Custom Text Drawing #" Labels need to change so we can easily move up or down buttons as was done previously |
Buttons.jpg / V - Attached On 2015-11-26 01:32:36 UTC - Size: 260.75 KB - 318 views |
[2015-11-26 01:45:03] |
This will be solved in the next release. We should have a release out in about two days. As we enhance the capabilities of the new Control Bar, sometimes there are changes which cause some unexpected issues. However, we will take care of these promptly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-26 01:46:07
[2015-11-26 01:46:14] |
Thank you!! I was about to pull some hair out.
