Date/Time: Fri, 03 May 2024 22:29:41 +0000
Interactive Brokers Linking up on DTS
View Count: 834
[2015-11-25 20:01:13] |
AP - Posts: 117 |
Hi - Few qs on the connectivity with Interactive Brokers - 1. Do I use the drop down called Interactive Brokers (Trading) in the DTS? 2. While username and password is my credentials with IB - what should I enter for the server name? 3. I am already paying Interactive Brokers for the data - can I get data when I am connected to IB in Sierra CHarts as I wish to route orders using SC-IB link? 4. I am paying for one subscription of SC and I use it to connect with CQG to trade futures. Can I use an another instance of Sierra CHarts with the same logging name for SC but this time have it connected to IB credentials? 5. I wish to do the (4) above on another computer - is that possible? Will appreciate help, please, Thanks, Amir |
[2015-11-26 04:32:37] |
1, 2. Refer to the instructions here: Interactive Brokers Trading Service: Setup Instructions 3. Yes. 4. Yes. Refer to: Using Multiple Data and Trading Services at the Same Time 5. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
