Date/Time: Sun, 05 May 2024 17:25:22 +0000
Having trouble setting up charts for the first time
View Count: 693
[2015-11-25 06:18:09] |
User638756 - Posts: 52 |
I put the RSI indicator on and its showing a 2 line. How can I get the 1 line with the bubble showing on the end. Also having trouble with the candlesticks showing globally. It reverts to the bar globally. Thanks! |
[2015-11-25 20:55:55] |
The answer is still pending. We need to do some documentation updates and review for this first.
[2015-11-26 05:04:56] |
Refer to the documentation here to hide a Study Subgraph: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DrawStyle Refer to the documentation here to enable the Name and Value labels for a Study Subgraph https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#NameValueLabels Refer to the documentation here to set Candlesticks as the default Graph Draw Type: https://www.sierrachart.com/index.php?page=doc/helpdetails20.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-26 05:05:35
