Date/Time: Wed, 08 May 2024 04:41:39 +0000
Status Bar on new Control Bar
View Count: 690
[2015-11-23 19:45:46] |
superdoug3 - Posts: 40 |
I have read the documentation on the use of Status Bar. With the merge of Status bar and Toolbar, I have lost the DF # since I keep toolbar on the right side of my chart. In the event of a Datafeed problem (screen freeze) would this DF # be very useful ? as I have never used DF # before I am removing Status Bar from my toolbar
[2015-11-23 19:56:00] |
You will still see the Status Bar on the Control Bar even if it is attached to the right side. You will see only a portion of it and enough to see the "DF" counter and the background color which is more than sufficient to monitor data feed status. The data feed Status Bar is always useful but the connection information is also on the title bar of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
