Date/Time: Wed, 08 May 2024 03:59:02 +0000
no data for MDAX
View Count: 744
[2015-11-23 10:32:50] |
User737065 - Posts: 23 |
Unfortunately I am not receiving data for the MDAX. My broker told me that everything is fine with them and the data provider, CQG. So I ask for your assistance. Thank you, regards |
[2015-11-23 10:49:52] |
What is the exact Symbol you are using for the chart? Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-23 11:15:52] |
F.US.F2MXZ15
[2015-11-23 11:39:36] |
Use: F.US.FDXMZ15 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-23 12:24:16] |
Issue is solved, thank you very much, regards
