Date/Time: Sun, 19 May 2024 18:37:18 +0000
Interactive Brokers
View Count: 2618
[2015-11-22 17:58:16] |
Richard Reyes - Posts: 98 |
I am trying to link up to IB with Sierra Charts and I keep getting numerous error messages. One message is "failed to connect to the Data and Trade Server". The other is "error connecting to Data or Trading Service". Is "Data and Trade Service" and "Data and Trade Server" referring to Sierra Charts or Interactive brokers? many Thanks.
[2015-11-22 21:11:18] |
It is referring to Interactive Brokers. If you need help, provide a copy of the Message Log by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-23 15:32:21] |
Please see Message Log below. I am having trouble connecting to Interactive Brokers. I have already spoke with the IB tech guy and he has run checks on his side of the linkup and he says that the problem is on the Sierra Charts side. Any and all help will be greatly appreciated. --------------------------------------------------------------------------- Interactive Brokers: Connecting to 7496:7496 | 2015-11-23 09:29:13 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-11-23 09:29:13 HTTP connection to www.sierrachart.com:80 (35) | Connected. | 2015-11-23 09:29:13 Requesting symbol settings for ib. Overwrite = off. | 2015-11-23 09:29:13 Symbol settings received. | 2015-11-23 09:29:13 Processed received symbol settings | 2015-11-23 09:29:14 Starting TWS auto-login thread. | 2015-11-23 09:29:17 TWS auto-login thread ending. | 2015-11-23 09:29:17 File >> Disconnect selected. | 2015-11-23 09:29:17 Interactive Brokers | Failed to connect to the data and trade server. | 2015-11-23 09:29:17 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-11-23 09:29:17 * Interactive Brokers | Disconnected. | 2015-11-23 09:29:17 HTTP connection to www.sierrachart.com:80 (35) | Closed. No error. | 2015-11-23 09:29:18 HTTP connection to www.sierrachart.com:80 (35) | Shutdown and closed. | 2015-11-23 09:29:18 Interactive Brokers: Connecting to 7496:7496 | 2015-11-23 09:29:31 Socket (0) | Error on address resolution. Windows error code 11001: No such host is known. | 2015-11-23 09:29:34 Interactive Brokers | Failed to connect to the data and trade server. | 2015-11-23 09:29:34 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-11-23 09:29:34 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-23 09:29:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-23 09:29:34 Interactive Brokers | Disconnected. | 2015-11-23 09:29:34 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-23 09:29:34 Starting TWS auto-login thread. | 2015-11-23 09:29:35 TWS auto-login thread ending. | 2015-11-23 09:29:35 |
[2015-11-23 17:49:07] |
You need to set Global Settings >> Data/Trade Service Settings >> Server to localhost:7496 This is explained in the set up instructions here: Interactive Brokers Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-23 18:28:05] |
I already have the Server set to 7496 in Sierra Charts. In IB I go to File>Application Settings>Global Configuration>API>Settings and set the Server to 7496. I already have Server set to 7496 in both Sierra Charts and IB. Per my previous email, I have spoken with the IB tech and he ran tests on my TWS installation and everything is working properly, that is why he told me that the problem has to be on the Sierra Charts side. Please advise.
[2015-11-23 18:40:00] |
The Server is not set right in Sierra Chart. It must be localhost:7496
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-23 18:40:35
[2015-11-23 20:24:39] |
"Localhost 7496" works and now I am getting 2 messages on my screen - "Symbol Is Unknown" and "Download Failed". I have followed the guidelines for IB symbol names - i.e., USD.JNY-CASH-IDEALPRO. I have also attached the applicable Message Log. Please advise and many thanks. ---------------------------------------------------------------------------------------- Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-11-23 14:19:26 Socket (59) | Connected. | 2015-11-23 14:19:26 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2015-11-23 14:19:26 Interactive Brokers | TWS server version: 76 | 2015-11-23 14:19:26 Interactive Brokers | Connected. Waiting for account information. | 2015-11-23 14:19:26 IB Account information received. | 2015-11-23 14:19:26 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2015-11-23 14:19:26 Interactive Brokers | Connected to Demo or Simulated account. | 2015-11-23 14:19:26 Interactive Brokers | Not previously connected to Live account. | 2015-11-23 14:19:26 Interactive Brokers | Requesting Trade Positions (IB account data updates) for account: DU25* | 2015-11-23 14:19:26 Next valid order ID: 1 | 2015-11-23 14:19:26 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2015-11-23 14:19:26 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2015-11-23 14:19:26 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2015-11-23 14:19:26 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2015-11-23 14:19:26 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2015-11-23 14:19:26 Next valid order ID: 1 | 2015-11-23 14:19:26 IB Account information received. | 2015-11-23 14:19:26 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2015-11-23 14:19:26 Interactive Brokers | Connected to Demo or Simulated account. | 2015-11-23 14:19:26 Interactive Brokers | Not previously connected to Live account. | 2015-11-23 14:19:26 Interactive Brokers | Received Trade Positions download end message for account DU25* | 2015-11-23 14:19:26 Interactive Brokers | Starting real-time market data updates for: USDCHF. ID: 1 | 2015-11-23 14:19:26 Interactive Brokers | Subscribing to Symbol: USDCHF, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-11-23 14:19:26 Interactive Brokers | Starting real-time market data updates for: USDJPY. ID: 2 | 2015-11-23 14:19:26 Interactive Brokers | Subscribing to Symbol: USDJPY, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-11-23 14:19:26 Interactive Brokers | Starting real-time market data updates for: USDMXN. ID: 3 | 2015-11-23 14:19:26 Interactive Brokers | Subscribing to Symbol: USDMXN, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-11-23 14:19:26 Symbol Error - USDCHF is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-11-23 14:19:26 Symbol Error - USDJPY is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-11-23 14:19:26 Symbol Error - USDCHF is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-11-23 14:19:26 Symbol Error - USDJPY is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-11-23 14:19:26 Interactive Brokers | Starting real-time market data updates for: USDCAD. ID: 4 | 2015-11-23 14:19:26 Interactive Brokers | Subscribing to Symbol: USDCAD, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-11-23 14:19:26 Symbol Error - USDMXN is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-11-23 14:19:26 Symbol Error - USDMXN is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-11-23 14:19:26 Symbol Error - USDCAD is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-11-23 14:19:26 Symbol Error - USDCAD is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-11-23 14:19:26 Intraday data recording state for symbol USDMXN is set to download pending. | 2015-11-23 14:19:29 HD Request # 63 | Downloading Intraday chart data for USDMXN to the file USDMXN.scid. Service: fxcm | 2015-11-23 14:19:29 HD Request # 63 | Download start Date-Time: 2015-11-23 14:03:12.000 | 2015-11-23 14:19:29 HD Request # 63 | Requesting a total of 0 days and 5777 seconds. | 2015-11-23 14:19:29 HD Request # 63 | IB Backfill - Seconds requested: 5777. Seconds Remaining: 0. | 2015-11-23 14:19:29 HD Request # 63 | Requesting 5777 Seconds of data at 30 secs with ending Date-Time at 2015-11-23 15:29:29 for USDMXN | 2015-11-23 14:19:29 HD Request # 63 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 5. | 2015-11-23 14:19:29 HD Request # 63 | Error downloading historical Intraday data for USDMXN. The symbol is unknown to the server. | 2015-11-23 14:19:29 * HD Request # 63 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USDMXN | 2015-11-23 14:19:29 HD Request # 63 | Intraday download COMPLETE for USDMXN. Completion time: 0s. Unique request ID: 62 | 2015-11-23 14:19:29 Removed historical data download ID 62 | 2015-11-23 14:19:29 Real-time Intraday chart data file updates started for USDMXN | 2015-11-23 14:19:29 Message from IB: No historical data query found for ticker id:5. IB Error Code: 366. Request ID: 5. | 2015-11-23 14:19:29 Intraday data recording state for symbol USDCAD is set to download pending. | 2015-11-23 14:19:29 HD Request # 64 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2015-11-23 14:19:29 HD Request # 64 | Download start Date-Time: 2015-11-23 14:03:13.000 | 2015-11-23 14:19:29 HD Request # 64 | Requesting a total of 0 days and 5776 seconds. | 2015-11-23 14:19:29 HD Request # 64 | IB Backfill - Seconds requested: 5776. Seconds Remaining: 0. | 2015-11-23 14:19:29 HD Request # 64 | Requesting 5776 Seconds of data at 30 secs with ending Date-Time at 2015-11-23 15:29:29 for USDCAD | 2015-11-23 14:19:29 HD Request # 64 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 6. | 2015-11-23 14:19:29 HD Request # 64 | Error downloading historical Intraday data for USDCAD. The symbol is unknown to the server. | 2015-11-23 14:19:29 * HD Request # 64 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USDCAD | 2015-11-23 14:19:29 HD Request # 64 | Intraday download COMPLETE for USDCAD. Completion time: 0s. Unique request ID: 63 | 2015-11-23 14:19:29 Removed historical data download ID 63 | 2015-11-23 14:19:29 Real-time Intraday chart data file updates started for USDCAD | 2015-11-23 14:19:29 Message from IB: No historical data query found for ticker id:6. IB Error Code: 366. Request ID: 6. | 2015-11-23 14:19:29 Intraday data recording state for symbol USDCHF is set to download pending. | 2015-11-23 14:19:29 HD Request # 65 | Downloading Intraday chart data for USDCHF to the file USDCHF.scid. Service: fxcm | 2015-11-23 14:19:29 HD Request # 65 | Download start Date-Time: 2015-11-23 14:03:18.000 | 2015-11-23 14:19:29 HD Request # 65 | Requesting a total of 0 days and 5771 seconds. | 2015-11-23 14:19:29 HD Request # 65 | IB Backfill - Seconds requested: 5771. Seconds Remaining: 0. | 2015-11-23 14:19:29 HD Request # 65 | Requesting 5771 Seconds of data at 30 secs with ending Date-Time at 2015-11-23 15:29:29 for USDCHF | 2015-11-23 14:19:29 HD Request # 65 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 7. | 2015-11-23 14:19:29 HD Request # 65 | Error downloading historical Intraday data for USDCHF. The symbol is unknown to the server. | 2015-11-23 14:19:29 * HD Request # 65 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USDCHF | 2015-11-23 14:19:29 HD Request # 65 | Intraday download COMPLETE for USDCHF. Completion time: 0s. Unique request ID: 64 | 2015-11-23 14:19:29 Removed historical data download ID 64 | 2015-11-23 14:19:29 Real-time Intraday chart data file updates started for USDCHF | 2015-11-23 14:19:29 Message from IB: No historical data query found for ticker id:7. IB Error Code: 366. Request ID: 7. | 2015-11-23 14:19:29 Intraday data recording state for symbol USDJPY is set to download pending. | 2015-11-23 14:19:29 HD Request # 66 | Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: fxcm | 2015-11-23 14:19:29 HD Request # 66 | Download start Date-Time: 2015-11-23 14:03:19.000 | 2015-11-23 14:19:29 HD Request # 66 | Requesting a total of 0 days and 5770 seconds. | 2015-11-23 14:19:29 HD Request # 66 | IB Backfill - Seconds requested: 5770. Seconds Remaining: 0. | 2015-11-23 14:19:29 HD Request # 66 | Requesting 5770 Seconds of data at 30 secs with ending Date-Time at 2015-11-23 15:29:29 for USDJPY | 2015-11-23 14:19:29 HD Request # 66 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 8. | 2015-11-23 14:19:29 HD Request # 66 | Error downloading historical Intraday data for USDJPY. The symbol is unknown to the server. | 2015-11-23 14:19:29 * HD Request # 66 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USDJPY | 2015-11-23 14:19:29 HD Request # 66 | Intraday download COMPLETE for USDJPY. Completion time: 0s. Unique request ID: 65 | 2015-11-23 14:19:29 Removed historical data download ID 65 | 2015-11-23 14:19:29 Real-time Intraday chart data file updates started for USDJPY | 2015-11-23 14:19:29 Message from IB: No historical data query found for ticker id:8. IB Error Code: 366. Request ID: 8. | 2015-11-23 14:19:29 Interactive Brokers | Requesting historical order fills for account DU2*. | 2015-11-23 14:19:31 Interactive Brokers | Received Open orders end message. | 2015-11-23 14:19:31 |
[2015-11-23 22:09:27] |
You cannot use the six letter Forex symbols with Interactive Brokers for trading. You need to use the symbols in File >> Find Symbol >> IB Forex. Like: EUR.USD-CASH-IDEALPRO Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-24 00:27:35] |
So I go to File >> Find Symbol>>IB Forex, but before that, don't I have to go to Data/Trade Service Settings and set the service to Interactive Brokers? Does this mean that I now need to also re-create my charts all over again to IB charts or can I copy them to the IB Forex accepted file names? Again, many thanks for all your help. Eventually, I will get there.
[2015-11-24 08:28:13] |
Based on the most recent Message Log you have posted, Sierra Chart is already set to use Interactive Brokers. So there is nothing more you need to do with that. You did not need to re-create your charts, you can change the symbol of an existing chart by following these instructions here: https://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
