Date/Time: Tue, 07 May 2024 08:46:18 +0000
DOM does not show Profit and loss
View Count: 844
[2015-11-20 22:03:20] |
User38993 - Posts: 61 |
I have 1329 and my dom and chart (chart trading mode enabled) do not show cumulative profit and loss. It use to show, but after update it does not. Currently it just says 0 regardless of profit or loss |
Capture_2015_11_21_07_02_40_294.png / V - Attached On 2015-11-20 22:03:14 UTC - Size: 16.92 KB - 288 views |
[2015-11-21 03:08:02] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_DailyProfitLossValue.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-21 21:15:05] |
I only tried this on simulated, but still profit loss is staying at 0. I don't understand why update would change all the settings.
[2015-11-22 02:37:51] |
We have no further information to provide other than the documentation. It is impossible for us to comment on this and say anything more because we do not have access to your Sierra Chart or have any idea as to what you are doing. An update of Sierra Chart will not change any settings. We have reviewed the documentation and made some additional updates to it. Please review it. The answer is there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-22 02:38:51
