Date/Time: Sun, 12 May 2024 02:20:05 +0000
data export
View Count: 695
[2015-11-19 19:56:33] |
jonno - Posts: 13 |
Hi I want to make a excel spreadsheet displaying a cell with individual month,week,day,4hr,hr,1min values for each currency pair. For about 20 or so symbols. I know i can add a spreadsheet study for this but, is there an easier way to do it.I would need many open charts all referencing their values at the same time into the spreadsheet.My plan is to create a currency dashboard from this info to gauge at a quick glance what was doing what. Kind Regards John |
[2015-11-19 21:19:31] |
You definitely need 20 charts open each with a Spreadsheet Study applied to them. They should all refer to the same Spreadsheet but output data to different Sheets. There is no other way to do this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-20 01:18:28
