Date/Time: Sun, 12 May 2024 20:17:42 +0000
Interactive brokers issues
View Count: 683
[2015-11-19 04:26:15] |
brown555 - Posts: 35 |
Hey guys - another issue from your favorite broker IB: previous day's volume isn't showing (daily bar for Nov 18th) and current day bar (Nov 19) isn't there. When I switch the chart in the attached image to an intraday time frame (e.g. 5 minutes) I get intraday data for Nov 19, but the daily bar does not show up (see attached) http://www.sierrachart.com/image.php?l=1447906687352.png |
[2015-11-19 16:37:39] |
Refer to this section here: https://www.sierrachart.com/index.php?page=doc/helpdetails12.html#h12.5 The volume data for the last bar will be coming from the Interactive Brokers data feed. If it is not correct, then it is not correct from Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
