Date/Time: Sun, 12 May 2024 16:26:56 +0000
Rectangle around Date-Time box
View Count: 762
[2015-11-18 21:55:49] |
sampater - Posts: 243 |
From the What Is New: Added rectangle around Date-Time box displayed on the timescale when using the Chart Values tool.
How can i disable this rectangle? It aggravates to seeing the Date-Time. |
[2015-11-18 22:24:43] |
This does not make any sense. How could it possibly aggravate it. There is no way to disable that and we would never provide such a capability.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-18 22:26:38
[2015-11-18 22:43:51] |
In the version 1325 there is an additional rectangle in the box around the Date-Time: see Box-1325 Before was: see Box-1316 |
Box-1325.png / V - Attached On 2015-11-18 22:42:34 UTC - Size: 1.41 KB - 252 views Box-1316.png / V - Attached On 2015-11-18 22:42:47 UTC - Size: 1.39 KB - 257 views |
[2015-11-18 22:51:59] |
In version 1325 it was not properly implemented. This has been solved in version 1328. The version notes are for version 1328.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-18 22:52:19
