Date/Time: Mon, 13 May 2024 14:31:57 +0000
CBV daily chart missing bars after roll-over to next month
View Count: 622
[2015-11-18 13:36:24] |
Greentea - Posts: 26 |
After performing rollover from previous month, CLF6 CBV missing bars on chart. non-CBV chart seems fine. Delete all data and reload obviously does not fix.
CLF6-NYMEX [CBV] Daily #1 2015-11-18 07_32_51.957.png / V - Attached On 2015-11-18 13:35:23 UTC - Size: 23.43 KB - 270 views |
[2015-11-18 16:59:23] |
Follow the instructions here to re-download the data for the last two futures contracts: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
