Date/Time: Fri, 03 May 2024 06:29:50 +0000
Quoteboard Historical Data
View Count: 1222
[2015-11-16 11:16:13] |
User842703 - Posts: 55 |
I started a Quoteboard list using the SC Historical Data for US symbols e.g. $DOWI, XLY and linked to Daily charts but none of the fields in the Quoteboard populate and all show 0. Is there a setting to change this?
[2015-11-16 17:36:38] |
Symbols that provide historical data only and not streaming real-time or delayed data, will only provide zero values on the Quote Board. Sometime during the next 3 months we will look into adding this capability though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-16 17:39:34
[2015-11-16 18:39:06] |
That would be very useful. For some reason the Quoteboard I have open for the real time FXCM data has now gone haywire. Earlier today it was correctly showing Daily Change/% change, now it is referencing some intra-day bar. For example the change in UK100 from Friday's close is +83 but is showing as -4 in the Quoteboard. |
[2015-11-16 23:34:24] |
This could be because the FXCM FIX data feed that we use does not provide a previous days closing price So the calculation of the daily price change is not always accurate if the data feed connection has been restarted to FXCM from our server. We will see how to improve upon this. But it is not something we can get too quickly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-16 23:35:39
[2017-09-19 09:24:48] |
mikeyhd - Posts: 1 |
Does the ability to use quoteboard for the delayed data work now? ()I still get 0) Thanks |
[2017-09-19 17:58:59] |
No. This is one of these lower priority items, which we do not expect to get to for a long time. It would likely still be another year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-09 06:58:17] |
User164231 - Posts: 278 |
Thanks Any improvement to the above? By having a historical data it may open the possibility to compare week to week changes. |
[2018-05-09 07:14:15] |
No, we would not expect anything done with this anytime soon.
