Date/Time: Sun, 12 May 2024 11:50:24 +0000
[User Discussion] - Down Arrows do not print properly
View Count: 762
[2015-11-16 10:33:35] |
djcurcio - Posts: 236 |
I have enclosed a screenshot that includes both up and down arrows in panel 2. Notice that the up green arrows print correctly while the down arrows (same size) only print a portion of the arrow. This seems to be an alignment problem. Thanks |
Down Arrows NG.PNG / V - Attached On 2015-11-16 10:33:29 UTC - Size: 185.29 KB - 274 views |
[2015-11-16 17:13:47] |
You need to use the Interactive Scale Range feature to expand the range of prices in that Chart Region: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#InteractiveScaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-19 10:32:00] |
Sorry, but no good. I've tried dragging the range all over the place and the down arrows barely print -ie no change. I've moved the up and down arrows to a separate panel - no good. See screenshot. |
Attachment Deleted. down arrows.PNG / V - Attached On 2015-11-19 10:31:26 UTC - Size: 129.05 KB - 263 views |
