Date/Time: Tue, 30 Apr 2024 03:35:33 +0000
create stop order of type SCT_ORDERTYPE_TRIGGERED_STEP_TRAILING_STOP
View Count: 1537
[2013-06-19 20:59:15] |
oz.shalom - Posts: 1 |
Hi, when i create an order with stop price and i change the AttachedOrderStop1Type to SCT_ORDERTYPE_TRIGGERED_STEP_TRAILING_STOP, how do i set the attached stop order the parameters TriggeredTrailStopTrailPriceOffset and TriggeredTrailStopTriggerPriceOffset ? thank you Oz |
[2013-06-21 00:56:10] |
Please refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html Hopefully that page should answer your questions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
