Date/Time: Sat, 18 May 2024 11:37:05 +0000
Chart value window font size
View Count: 1067
[2015-11-10 15:25:29] |
User714791 - Posts: 2 |
Is there a way to make this chart value window larger so the txt is easier to see. Or can I increase font size?
Attachment Deleted. Private File |
[2015-11-10 18:15:46] |
Yes, this is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ToolValuesWindowFont Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
