Date/Time: Sat, 04 May 2024 21:55:33 +0000
Spreadsheet systems for trading
View Count: 671
[2015-11-10 00:31:34] |
AC95711 - Posts: 3 |
I developed several spreadsheet systems for trading. Depending on market conditions, I would like to enable/disable(send or stop sending orders to trade service). As of now I have to open the spreadsheet for each strategy and each chart and set field J28 to True or False. This is cumbersome – a simple control box could do the same, but I don’t know how to build such a box as shown below. How can this be done ? Any help is much appreciated. If there is enough interest from other traders, is this something you would consider adding as a standard feature? Chart strat1 strat2 1 on/off on/off 2 on/off on/off |
[2015-11-10 01:08:02] |
This is not easily developed, and we are not able to take any new suggestions now.
[2015-11-10 01:32:38] |
Sawtooth - Posts: 3993 |
If all charts of the same strategy are in the same chartbook, you can add a sheet not associated with a chart, then use a cell that all of the J28 cells reference. This would allow you to turn on/off all of them with one cell.
