Date/Time: Mon, 29 Apr 2024 16:15:18 +0000
Chart indicator value display question
View Count: 736
[2015-11-09 12:05:44] |
User38993 - Posts: 61 |
Currently my indicator value displays on left corner of chart. Is it possible to move to right bottom corner of chart?
[2015-11-09 17:53:50] |
We need to know specifically what you are referring to. Post an image of the chart by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Let us know specifically what you are referring to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-09 17:54:02
