Date/Time: Fri, 03 May 2024 10:32:59 +0000
Trade DOM High/Low markers
View Count: 951
[2015-11-09 08:56:29] |
User842703 - Posts: 55 |
I've figured out the Red/Green lines represent the High-Low markers of the current session and cannot be changed however they appear to be incorrect. As of right now 08.50 GMT for the GER30 symbol they are showing 11028/11029 and 10949/10950 depending on whether you use above or below the line. The actual High/Low of the session are 11014 and 10951 and I've noticed similar discrepancies with other symbols. Is there a way to fix this?
[2015-11-09 09:07:13] |
No, there is no way to change this. These are based upon the data received from FXCM.
[2015-11-09 15:13:53] |
Sawtooth - Posts: 3992 |
You could disable the High-Low markers, then add the Study/Price Overlay study referencing the Daily OHLC study on another chart. However, the lines won't be in the price column.
[2015-11-09 18:15:25] |
I didn't think it was possible to disable these markers, and can't find the option in Settings.
[2015-11-09 18:43:18] |
Go to Global Settings >> Graphics Settings >> scroll down to Trade DOM Daily High Line and Trade DOM Daily Low Line and uncheck 'Enable' on each.
[2015-11-09 19:39:53] |
Ok got it thanks.
