Date/Time: Tue, 07 May 2024 01:29:29 +0000
top numbers are missing on price candle/ladder
View Count: 755
[2015-11-09 07:19:59] |
User486035 - Posts: 9 |
I configured the number bars and found that top pullback numbers are missing. Can you point me what parameters I have to set to get the numbers top and bottom of every price candle(number bar). I am attaching 3 screenshots. In example the circled numbers are missing in my chart and you will see in result picture what I have in my chartbook. I have also included the numberbarsettings.jpg for you to see which parameter has to be set to get the numbers on top. top numbers will be negative and bottom numbers will be positive. Thanks and appreciated. |
ExampleBar.JPG / V - Attached On 2015-11-09 07:13:59 UTC - Size: 163.58 KB - 269 views NumberBarSettings.jpg / V - Attached On 2015-11-09 07:14:07 UTC - Size: 456.6 KB - 287 views Result.JPG / V - Attached On 2015-11-09 07:14:15 UTC - Size: 116.78 KB - 275 views Attachment Deleted. |
[2015-11-09 08:36:48] |
Refer to the documentation here for the Show Historical Pullback AskVolume BidVolume Difference input: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#InputSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
