Date/Time: Mon, 29 Apr 2024 11:39:51 +0000
Study Overlay
View Count: 720
[2015-11-08 15:39:42] |
User170575 - Posts: 221 |
Hi, Using the "Study/Price Overlay" I am trying to place a moving average "Line at Last Bar to Edge" from a 5Min Chart to overlay on a tick chart. I cannot get the line to show on the tick chart. Your thoughts appreciated. Thanks, Cy |
[2015-11-09 01:10:47] |
First, it is important that you set the Draw Style to Line to start off with until you get the overlay working properly. Refer to the documentation here for the study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s118 Set Fill Blanks with Last Value to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-09 01:11:15
