Date/Time: Sun, 05 May 2024 07:58:46 +0000
TPO chart
View Count: 763
[2015-11-07 21:41:26] |
User40526 - Posts: 166 |
I have read the documentation and searched the support board and cannot resolve my problem I want to limit the TPO's in the TPO profile chart to 8 am Central time to 1:30 pm central time I have the chart settings set to this time frame and do not use an evening session I have the same time settings for the Single Profile Start Date-Time and End Date-Time However my TPO plot runs from 8 am until midnight. I can't find a way to limit it |
[2015-11-07 22:22:00] |
I have the same time settings for the Single Profile Start Date-Time and End Date-Time However my TPO plot runs from 8 am until midnight. I can't find a way to limit it http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php Possibly you have the Hours, Minutes, Seconds fields not set correctly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-07 22:22:25
[2015-11-09 11:47:07] |
The session time for this TPO chart is HH:MM:SS = START TIME 08:00:00 END TIME 01:30:00 and Use Evening Session is unchecked Bar Period Type is Days-Mins-Secs Per Bar = 0-1-0 So I don't see what I'm missing because it plots from 8 am until midnight The Global Time Setting is Chicago, so that's correct. I have Load Weekend Data unchecked, and yet it has plotted some Sunday TPO's Thanks |
[2015-11-09 17:55:57] |
Set the End Time to 13:30:00.
[2015-11-09 20:27:50] |
THANK YOU!
