Date/Time: Sat, 27 Apr 2024 05:54:54 +0000
Export Intraday Data to Text File
View Count: 820
[2015-11-07 14:34:10] |
User847587 - Posts: 18 |
I’m interested in saving 60 minute data to .txt for further analysis. However, the Edit/Export Intraday Data function is saving what appears to be raw data from the ticker tape. This file is enormous at over 300MB, exceeding Excel’s limits on rows allowed. Help me find the right function so I can analyze 60 minute data. Thank you.
[2015-11-09 00:40:07] |
Use this command: https://www.sierrachart.com/index.php?page=doc/doc_EditMenu.html#ExportBarDatatoText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
