Date/Time: Mon, 29 Apr 2024 20:13:53 +0000
Bid Ask Volume Ratio
View Count: 2181
[2013-06-19 15:12:58] |
User28682 - Posts: 233 |
I would like to have this study update only when the bar completes, NOT intrabar. Bid Ask Volume Ratio Could you show me how to change the code for this? or make the change? Thank you Tom |
[2013-06-19 18:28:24] |
In Sierra Chart, all studies are continuously updated unless they are programmed to ignore the last bar in the chart. This is possible. Here is the code for this study which has this code added: SCSFExport scsf_BidAskVolumeRatio(SCStudyInterfaceRef sc)
{ SCSubgraphRef VolRatioAvg = sc.Subgraph[0]; SCSubgraphRef ZeroLine = sc.Subgraph[1]; SCFloatArrayRef ExtraArrayRatio = sc.Subgraph[0].Arrays[0]; SCInputRef InMALength = sc.Input[0]; SCInputRef InMAType = sc.Input[1]; if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "Bid Ask Volume Ratio"; sc.StudyDescription = "Bid Ask Volume Ratio"; sc.AutoLoop = 1; //During development set this flag to 1, so the DLL can be modified. When development is completed, set it to 0 to improve performance. sc.FreeDLL = 0; VolRatioAvg.Name = "Vol Ratio Avg"; VolRatioAvg.DrawStyle = DRAWSTYLE_LINE; VolRatioAvg.PrimaryColor = RGB(0,255,0); VolRatioAvg.DrawZeros = false; ZeroLine.Name = "Zero Line"; ZeroLine.DrawStyle = DRAWSTYLE_LINE; ZeroLine.PrimaryColor = RGB(255,0,255); ZeroLine.DrawZeros = true; InMALength.Name = "Length"; InMALength.SetInt(14); InMALength.SetIntLimits(1,MAX_STUDY_LENGTH); InMAType.Name= "Moving Average Type"; InMAType.SetMovAvgType(MOVAVGTYPE_EXPONENTIAL); return; } if(sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_NOT_CLOSED) return; // Do data processing float UpVol = sc.AskVolume[sc.Index]; float DownVol = sc.BidVolume[sc.Index]; float TotalVol = UpVol + DownVol; if (TotalVol > 0) ExtraArrayRatio[sc.Index] = 100.0f * (UpVol - DownVol) / TotalVol; else ExtraArrayRatio[sc.Index] = 0.0f; sc.MovingAverage(ExtraArrayRatio, VolRatioAvg, InMAType.GetMovAvgType(), InMALength.GetInt()); } To compile this study into a DLL file which can then be used, refer to this page: https://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-19 21:12:33] |
Hi Thanks, so are you saying the code you sent me includes what is needed to make the bar update only at its close? Then I just need to compile the code into a DLL, or something simpler? Thanks Tom |
[2013-06-19 21:13:52] |
Yes it does include what is needed to have it only update on close. You do need to compile it into a DLL using the instructions linked to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-19 22:20:09] |
Thanks! I think I actually got it to work. :-) Tom |
[2013-06-19 22:32:13] |
If one inserts the volume study, you can see a text volume counter on the bottom of the study. Is there one for Ticks(the number of ticks)? I would want to see how many ticks are occurring. Thanks Tom |
