Date/Time: Sun, 12 May 2024 23:03:33 +0000
Strage position discrepency
View Count: 734
[2015-11-06 17:04:23] |
ejtrader - Posts: 688 |
SC Team - Today - ran into a strange issue with position discrepency - live trade. Attached is the image - left side chart shows - short and right side chart shows no position. From broker point of view - I am flat at this time. Don't recall running into this issue before and not sure what should be done to clear this situation. There was a carry over position from yesterday. With "Use Global Fill Calculated position on" - charts differ. With "Use Fill Calculated position off" - Both charts show identical. Hopefully this clears itself close of the day - but this issue is strange to me. Initially was on version 1317 - and updated to 1320 to see if it makes any difference and it didn't. Edit - This is not an urgent issue and might correct itself close of the day. Just thought of mentioning as it seems very strange behavior :) Thanks Date Time Of Last Edit: 2015-11-06 17:32:52
Private File Private File |
[2015-11-06 18:41:07] |
Uncheck Chart >> Chart Settings >> Advanced Settings >> Load Order Fills for Current Day Only for all of the charts.
[2015-11-06 18:42:50] |
Bingo. Assuming might be one of the options recently introduced (or if this is not new - might have been accidentally enabled for a single chart in question). All good now. Thanks Date Time Of Last Edit: 2015-11-06 19:13:36
