Date/Time: Sat, 11 May 2024 08:39:40 +0000
need help with getting Renko Bars to display on chart
View Count: 665
[2015-11-06 16:59:52] |
User635080 - Posts: 1 |
Hi there, I tried to get renko bars to show on a 1 minute intra day chart of ES emini. I can add the button to the tool bar but it is grayed out. Also, if I try to activate the RBW from Chart settings, nothing happens. Where am I going wrong? Thanks |
[2015-11-06 18:04:38] |
Follow the instructions here for Renko Bars: https://www.sierrachart.com/index.php?page=doc/doc_RenkoCharts.html What does RBW stand for? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-06 18:04:59
