Date/Time: Fri, 03 May 2024 08:09:14 +0000
sc.GetSummation compiler error
View Count: 692
[2015-11-05 17:29:21] |
Johnny - Posts: 99 |
Hello, I want to be able to change the length setting of the sc.GetSummation function from the study settings so I have created an input that will track the number of bars. But when I try to use it in the function I get the following error: no known conversion for argument 3 from 's_SCInput_145' to 'int'.
[2015-11-05 17:45:44] |
You need to use the GetInt function on the input object.
