Date/Time: Sun, 12 May 2024 10:34:33 +0000
TPO chart for ES issue
View Count: 727
[2015-11-05 15:17:23] |
User91630 - Posts: 25 |
My TPO chart for the ES on date 11/2/2015 runs the full length of the ES contract, from 0 to 2100ish. I have tried resetting the TPO and reloading the regular chart with no fix. When I pull the TPO study from the chart everything seems fine. It is only when I load the study that there seems to be an issue. It is under my chartbook ES TPO. Thank you.
[2015-11-05 17:20:00] |
We are not understanding this. Provide an image of the chart showing that particular TPO Profile, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-05 17:30:00] |
http://www.sierrachart.com/image.php?l=1446744535606.png
[2015-11-05 17:44:03] |
There is a data error. Right-click before the 2015-11-2 date in the chart and select Delete and Download Data Also make sure you have Chart >> Chart Settings >> Advanced Settings >>Allow Zero Values disabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-06 12:10:03
[2015-11-06 12:06:40] |
Very good, all fixed. Thank you.
