Date/Time: Sun, 05 May 2024 13:09:10 +0000
[User Discussion] - GAp Disply
View Count: 1071
[2015-11-05 02:06:31] |
User167108 - Posts: 49 |
Is there any way to display gap in text for mat on chart some where in corner ? Fot example /es some thing like this Todays Gap +6 |
[2015-11-05 06:04:35] |
Sawtooth - Posts: 3993 |
Yes. Here's the basic idea: 1) Add the Daily OHLC study and set the Reference Days Back to 1 2) Add another Daily OHLC study and set the Reference Days Back to 0 3) Add the Study Subgraphs Difference study and reference the Close of the first Daily OHLC study and the Open of the second Daily OHLC study 4) Use the Text Display for Study from Chart study to display the value Date Time Of Last Edit: 2015-11-05 18:47:50
[2015-11-06 15:10:08] |
It working Great .. Thanks a lot , Tomgilb. But its disappearing after market close . means i see zero there .. Is there any way i can see everyday gap amount on the chart ? Appreciate your time and help
Date Time Of Last Edit: 2015-11-06 15:10:58
[2015-11-06 16:03:17] |
To display the current day's RTH gap after market close on a Globex chart, you'd need to put studies 1-3 on a RTH chart and study 4 on a globex chart, referencing the RTH chart.
[2015-11-06 17:46:48] |
Thanks Tomgilb. Please find attached chart . It is RTH chart and displaying todays GAP only . Would it be possible to see everday gap ? .. It is showing todays gap 3.5 only .. I would like see previous days GAP also like any other data ( value areas lines ) . is it possible ? Appreciate your time . Thanks a lot
GAPStudy.cht - Attached On 2015-11-06 17:42:13 UTC - Size: 104.55 KB - 306 views |
[2015-11-06 19:06:08] |
In your chartbook, the gap lines are already drawn. Yesterday's close is orange, today's open is white. Some things you could do: -You could fill the difference of these lines with a color. -You could use the Value On High/Value on Low draw styles and place the gap value on the high or low of every candle. -You could use the Spreadsheet Study study and with a formula place the value on the high or low of the last bar of each day. The displayed 3.5 is only today's opening gap; displaying the gap value like this within each day for all days is not possible without custom programming. |
[2015-11-06 22:52:41] |
Tomgilb, Thank you very much . |
