Date/Time: Sun, 05 May 2024 15:08:49 +0000
Chart Dom Colum:P&L
View Count: 761
[2015-11-04 20:11:24] |
crazybears - Posts: 314 |
Hi can be set to display P&L in currency instead of points ? thanks |
[2015-11-05 03:05:24] |
Refer to this section here: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ProfitLossDisplay This is also explained in the Chart Trading documentation. Please refer to the documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-05 03:05:48
[2015-11-05 04:40:28] |
Hi Sierra Chart Engineering im sorry, it's my fault, i have misspelled , i meant the far right column of the chart , i tried several times without results. http://www.sierrachart.com/image.php?l=1446697870514.png thanks |
[2015-11-05 05:06:51] |
How to change what that column displays is documented on the "Chart Trading" page. Refer to the Table of Contents.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-05 05:07:01
