Date/Time: Wed, 08 May 2024 06:34:20 +0000
[User Discussion] - Swing High and Low Indicator
View Count: 2052
[2015-11-03 03:13:28] |
Acro - Posts: 436 |
Hi, I appreciate that you can have equal highs and lows in this great fractal marker. Is there any chance that those equal lows can be merged so they appear once and not twice or three times ? |
[2016-02-10 13:37:47] |
tradernikki - Posts: 41 |
Hello SC, I would like to know if this feature will be implemented in the future. It is especially useful when using renko bars. Regards, Nikki |
2016-02-10_20-35-23.png / V - Attached On 2016-02-10 13:37:02 UTC - Size: 8.11 KB - 404 views |
[2016-03-01 02:20:32] |
You are able to modify this study easily to meet your requirements. That is the best thing rather than relying on us. This is something so simple for users to do. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
