Date/Time: Sat, 12 Sep 2026 07:21:39 +0000
Cumulative Delta Bars indicator subgraph request
View Count: 3126
| [2013-03-27 16:53:30] |
| User22396 - Posts: 191 |
as part of the subgraph output can you add a zero line? thanks |
| [2013-03-27 18:54:33] |
This can be done. Please see: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingHorizontalLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-03-27 18:57:06] |
thanks for the reply...I do use horizontal line at the moment but thought a zero line as part of the study would be very easy to add in an upcoming release thanks again b |
| [2013-03-27 19:13:06] |
This will not be done. You need to use the Line study.
