Date/Time: Sun, 26 May 2024 02:26:54 +0000
Unable to connect
View Count: 682
[2015-11-02 01:01:21] |
NGtrader - Posts: 12 |
Here is a copy of the log: Software version: 1307 | 2015-11-01 16:56:17 Uses Old Spreadsheets | 2015-11-01 16:56:17 Usage end date: 2016-01-03 | 2015-11-01 16:56:17 Enabled for: Advanced Features. | 2015-11-01 16:56:17 Enabled for: Advanced Features 2. | 2015-11-01 16:56:17 Enabled for: Sierra Chart Historical Data Service. | 2015-11-01 16:56:17 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2015-11-01 16:56:17 Enabled for: CME, CBOT, NYMEX, COMEX exchanges for trading accounts. | 2015-11-01 16:56:17 Received 1 data feed usernames. | 2015-11-01 16:56:17 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-11-01 16:56:17 Current selected Data/Trading service: CTS T4 FIX | 2015-11-01 16:56:17 Chart Update Interval: 500 | 2015-11-01 16:56:17 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-11-01 16:56:17 2015-11-01 16:56:17 Local computer time | 2015-11-01 16:56:17 2015-11-02 00:56:17 Local computer time in UTC | 2015-11-01 16:56:17 2015-11-01 16:56:17 Local computer time in SC Time Zone | 2015-11-01 16:56:17 2015-11-02 00:56:17 Server time in UTC | 2015-11-01 16:56:17 Local computer UTC time and Server UTC time difference: 178 seconds. | 2015-11-01 16:56:17 Notice: Your computer's clock is off by 178 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2015-11-01 16:56:17 Program path: F:\Sierra Chart\ | 2015-11-01 16:56:17 Data Files path: F:\Sierra Chart\Data\ | 2015-11-01 16:56:17 OS Version Number: 6.1 | 2015-11-01 16:56:17 Locale Information: C | 2015-11-01 16:56:17 Checking for new symbol settings for cts | 2015-11-01 16:56:17 Requesting symbol settings for cts. Overwrite = on. | 2015-11-01 16:56:18 Symbol settings received. | 2015-11-01 16:56:19 Processed received symbol settings | 2015-11-01 16:56:19 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-11-01 16:56:22 CTS FIX - Firm: GFET | 2015-11-01 16:56:22 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2015-11-01 16:56:22 CTS FIX socket (4) | Connected. | 2015-11-01 16:56:22 CTS FIX socket (4) | Starting TLS 1.0 connection. | 2015-11-01 16:56:22 CTS FIX socket (4) | SSL connection established. | 2015-11-01 16:56:22 CTS FIX: Sending the Logon message. | 2015-11-01 16:56:22 CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:22 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:25.54645=1372=A373=1058=Sending Time Accuracy problem10=186 | 2015-11-01 16:56:22 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:22 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:25.54645=1372=A373=1058=Sending Time Accuracy problem10=186 | 2015-11-01 16:56:22 * CTS FIX socket (4) | Closed. No error. | 2015-11-01 16:56:22 CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:22 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:25.54658=FIXLogin Time Tag Accuracy Problem - Out of time window10=226 | 2015-11-01 16:56:22 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:22 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:25.54658=FIXLogin Time Tag Accuracy Problem - Out of time window10=226 | 2015-11-01 16:56:22 * CTS FIX socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-01 16:56:22 CTS FIX socket (4) | SSL has been shut down. | 2015-11-01 16:56:22 CTS FIX socket (4) | SSL object has been freed. SSL state is now disconnected. | 2015-11-01 16:56:22 CTS FIX socket (4) | Shutdown and closed. | 2015-11-01 16:56:22 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2015-11-01 16:56:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-01 16:56:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-01 16:56:22 CTS FIX: DisconnectFIX called. | 2015-11-01 16:56:23 CTS FIX Historical Data: DisconnectFIX called. | 2015-11-01 16:56:23 CTS FIX: Disconnected. | 2015-11-01 16:56:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-01 16:56:23 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-11-01 16:56:26 CTS FIX - Firm: GFET | 2015-11-01 16:56:26 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2015-11-01 16:56:26 CTS FIX socket (5) | Connected. | 2015-11-01 16:56:26 CTS FIX socket (5) | Starting TLS 1.0 connection. | 2015-11-01 16:56:26 CTS FIX socket (5) | SSL connection established. | 2015-11-01 16:56:26 CTS FIX: Sending the Logon message. | 2015-11-01 16:56:26 CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:26 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:29.34145=1372=A373=1058=Sending Time Accuracy problem10=183 | 2015-11-01 16:56:26 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:26 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:29.34145=1372=A373=1058=Sending Time Accuracy problem10=183 | 2015-11-01 16:56:26 * CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:26 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:29.34158=FIXLogin Time Tag Accuracy Problem - Out of time window10=223 | 2015-11-01 16:56:26 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:26 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:29.34158=FIXLogin Time Tag Accuracy Problem - Out of time window10=223 | 2015-11-01 16:56:26 * CTS FIX socket (5) | Closed. No error. | 2015-11-01 16:56:26 CTS FIX socket (5) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-01 16:56:26 CTS FIX socket (5) | SSL has been shut down. | 2015-11-01 16:56:26 CTS FIX socket (5) | SSL object has been freed. SSL state is now disconnected. | 2015-11-01 16:56:26 CTS FIX socket (5) | Shutdown and closed. | 2015-11-01 16:56:26 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2015-11-01 16:56:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-01 16:56:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-01 16:56:26 CTS FIX: DisconnectFIX called. | 2015-11-01 16:56:26 CTS FIX Historical Data: DisconnectFIX called. | 2015-11-01 16:56:26 CTS FIX: Disconnected. | 2015-11-01 16:56:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-01 16:56:26 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-11-01 16:56:29 CTS FIX - Firm: GFET | 2015-11-01 16:56:29 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2015-11-01 16:56:29 CTS FIX socket (6) | Connected. | 2015-11-01 16:56:29 CTS FIX socket (6) | Starting TLS 1.0 connection. | 2015-11-01 16:56:29 CTS FIX socket (6) | SSL connection established. | 2015-11-01 16:56:30 CTS FIX: Sending the Logon message. | 2015-11-01 16:56:30 CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:30 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:33.21245=1372=A373=1058=Sending Time Accuracy problem10=175 | 2015-11-01 16:56:30 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:30 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:33.21245=1372=A373=1058=Sending Time Accuracy problem10=175 | 2015-11-01 16:56:30 * CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:30 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:33.21258=FIXLogin Time Tag Accuracy Problem - Out of time window10=215 | 2015-11-01 16:56:30 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:30 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:33.21258=FIXLogin Time Tag Accuracy Problem - Out of time window10=215 | 2015-11-01 16:56:30 * CTS FIX socket (6) | Closed. No error. | 2015-11-01 16:56:30 CTS FIX socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-01 16:56:30 CTS FIX socket (6) | SSL has been shut down. | 2015-11-01 16:56:30 CTS FIX socket (6) | SSL object has been freed. SSL state is now disconnected. | 2015-11-01 16:56:30 CTS FIX socket (6) | Shutdown and closed. | 2015-11-01 16:56:30 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2015-11-01 16:56:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-01 16:56:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-01 16:56:30 CTS FIX: DisconnectFIX called. | 2015-11-01 16:56:30 CTS FIX Historical Data: DisconnectFIX called. | 2015-11-01 16:56:30 CTS FIX: Disconnected. | 2015-11-01 16:56:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-01 16:56:30 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-11-01 16:56:33 CTS FIX - Firm: GFET | 2015-11-01 16:56:33 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2015-11-01 16:56:33 CTS FIX socket (7) | Connected. | 2015-11-01 16:56:33 CTS FIX socket (7) | Starting TLS 1.0 connection. | 2015-11-01 16:56:33 CTS FIX socket (7) | SSL connection established. | 2015-11-01 16:56:33 CTS FIX: Sending the Logon message. | 2015-11-01 16:56:34 CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:34 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:36.74445=1372=A373=1058=Sending Time Accuracy problem10=188 | 2015-11-01 16:56:34 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:34 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:36.74445=1372=A373=1058=Sending Time Accuracy problem10=188 | 2015-11-01 16:56:34 * CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:34 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:36.74458=FIXLogin Time Tag Accuracy Problem - Out of time window10=228 | 2015-11-01 16:56:34 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:34 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:36.74458=FIXLogin Time Tag Accuracy Problem - Out of time window10=228 | 2015-11-01 16:56:34 * CTS FIX socket (7) | Closed. No error. | 2015-11-01 16:56:34 CTS FIX socket (7) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-01 16:56:34 CTS FIX socket (7) | SSL has been shut down. | 2015-11-01 16:56:34 CTS FIX socket (7) | SSL object has been freed. SSL state is now disconnected. | 2015-11-01 16:56:34 CTS FIX socket (7) | Shutdown and closed. | 2015-11-01 16:56:34 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2015-11-01 16:56:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-01 16:56:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-01 16:56:34 CTS FIX: DisconnectFIX called. | 2015-11-01 16:56:34 CTS FIX Historical Data: DisconnectFIX called. | 2015-11-01 16:56:34 CTS FIX: Disconnected. | 2015-11-01 16:56:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-01 16:56:34 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-11-01 16:56:37 CTS FIX - Firm: GFET | 2015-11-01 16:56:37 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2015-11-01 16:56:37 CTS FIX socket (8) | Connected. | 2015-11-01 16:56:37 CTS FIX socket (8) | Starting TLS 1.0 connection. | 2015-11-01 16:56:37 CTS FIX socket (8) | SSL connection established. | 2015-11-01 16:56:37 CTS FIX: Sending the Logon message. | 2015-11-01 16:56:37 CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:37 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:40.27445=1372=A373=1058=Sending Time Accuracy problem10=181 | 2015-11-01 16:56:37 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:37 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:40.27445=1372=A373=1058=Sending Time Accuracy problem10=181 | 2015-11-01 16:56:37 * CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:37 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:40.27558=FIXLogin Time Tag Accuracy Problem - Out of time window10=222 | 2015-11-01 16:56:37 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:37 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:40.27558=FIXLogin Time Tag Accuracy Problem - Out of time window10=222 | 2015-11-01 16:56:37 * CTS FIX socket (8) | Closed. No error. | 2015-11-01 16:56:37 CTS FIX socket (8) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-01 16:56:37 CTS FIX socket (8) | SSL has been shut down. | 2015-11-01 16:56:37 CTS FIX socket (8) | SSL object has been freed. SSL state is now disconnected. | 2015-11-01 16:56:37 CTS FIX socket (8) | Shutdown and closed. | 2015-11-01 16:56:37 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2015-11-01 16:56:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-01 16:56:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-01 16:56:37 CTS FIX: DisconnectFIX called. | 2015-11-01 16:56:37 CTS FIX Historical Data: DisconnectFIX called. | 2015-11-01 16:56:37 CTS FIX: Disconnected. | 2015-11-01 16:56:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-01 16:56:37 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-11-01 16:56:40 CTS FIX - Firm: GFET | 2015-11-01 16:56:40 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2015-11-01 16:56:40 CTS FIX socket (9) | Connected. | 2015-11-01 16:56:40 CTS FIX socket (9) | Starting TLS 1.0 connection. | 2015-11-01 16:56:40 CTS FIX socket (9) | SSL connection established. | 2015-11-01 16:56:40 CTS FIX: Sending the Logon message. | 2015-11-01 16:56:41 CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:41 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:43.80045=1372=A373=1058=Sending Time Accuracy problem10=179 | 2015-11-01 16:56:41 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:41 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:43.80045=1372=A373=1058=Sending Time Accuracy problem10=179 | 2015-11-01 16:56:41 * CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:41 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:43.80058=FIXLogin Time Tag Accuracy Problem - Out of time window10=219 | 2015-11-01 16:56:41 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:41 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:43.80058=FIXLogin Time Tag Accuracy Problem - Out of time window10=219 | 2015-11-01 16:56:41 * CTS FIX socket (9) | Closed. No error. | 2015-11-01 16:56:41 CTS FIX socket (9) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-01 16:56:41 CTS FIX socket (9) | SSL has been shut down. | 2015-11-01 16:56:41 CTS FIX socket (9) | SSL object has been freed. SSL state is now disconnected. | 2015-11-01 16:56:41 CTS FIX socket (9) | Shutdown and closed. | 2015-11-01 16:56:41 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2015-11-01 16:56:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-01 16:56:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-01 16:56:41 CTS FIX: DisconnectFIX called. | 2015-11-01 16:56:41 CTS FIX Historical Data: DisconnectFIX called. | 2015-11-01 16:56:41 CTS FIX: Disconnected. | 2015-11-01 16:56:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-01 16:56:41 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-11-01 16:56:44 CTS FIX - Firm: GFET | 2015-11-01 16:56:44 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2015-11-01 16:56:44 CTS FIX socket (10) | Connected. | 2015-11-01 16:56:44 CTS FIX socket (10) | Starting TLS 1.0 connection. | 2015-11-01 16:56:44 CTS FIX socket (10) | SSL connection established. | 2015-11-01 16:56:44 CTS FIX: Sending the Logon message. | 2015-11-01 16:56:44 CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:44 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:47.37145=1372=A373=1058=Sending Time Accuracy problem10=186 | 2015-11-01 16:56:44 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:44 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:47.37145=1372=A373=1058=Sending Time Accuracy problem10=186 | 2015-11-01 16:56:44 * CTS FIX: Received a Logout message. Text = FIXLogin Time Tag Accuracy Problem - Out of time window | 2015-11-01 16:56:44 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-11-01 16:56:44 CTS FIX socket (10) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-01 16:56:44 CTS FIX socket (10) | SSL has been shut down. | 2015-11-01 16:56:44 CTS FIX socket (10) | SSL object has been freed. SSL state is now disconnected. | 2015-11-01 16:56:44 CTS FIX socket (10) | Shutdown and closed. | 2015-11-01 16:56:44 CTS FIX: Logged out and disconnected. | 2015-11-01 16:56:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-01 16:56:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-01 16:56:44 CTS FIX: DisconnectFIX called. | 2015-11-01 16:56:44 CTS FIX Historical Data: DisconnectFIX called. | 2015-11-01 16:56:44 CTS FIX: Disconnected. | 2015-11-01 16:56:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-01 16:56:44 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-11-01 16:56:47 CTS FIX - Firm: GFET | 2015-11-01 16:56:47 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2015-11-01 16:56:47 CTS FIX socket (11) | Connected. | 2015-11-01 16:56:48 CTS FIX socket (11) | Starting TLS 1.0 connection. | 2015-11-01 16:56:48 CTS FIX socket (11) | SSL connection established. | 2015-11-01 16:56:48 CTS FIX: Sending the Logon message. | 2015-11-01 16:56:48 CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:48 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:51.01845=1372=A373=1058=Sending Time Accuracy problem10=179 | 2015-11-01 16:56:48 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:48 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:51.01845=1372=A373=1058=Sending Time Accuracy problem10=179 | 2015-11-01 16:56:48 * CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:48 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:51.01958=FIXLogin Time Tag Accuracy Problem - Out of time window10=220 | 2015-11-01 16:56:48 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:48 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:51.01958=FIXLogin Time Tag Accuracy Problem - Out of time window10=220 | 2015-11-01 16:56:48 * CTS FIX socket (11) | Closed. No error. | 2015-11-01 16:56:48 CTS FIX socket (11) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-01 16:56:48 CTS FIX socket (11) | SSL has been shut down. | 2015-11-01 16:56:48 CTS FIX socket (11) | SSL object has been freed. SSL state is now disconnected. | 2015-11-01 16:56:48 CTS FIX socket (11) | Shutdown and closed. | 2015-11-01 16:56:48 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2015-11-01 16:56:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-01 16:56:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-01 16:56:48 CTS FIX: DisconnectFIX called. | 2015-11-01 16:56:48 CTS FIX Historical Data: DisconnectFIX called. | 2015-11-01 16:56:48 CTS FIX: Disconnected. | 2015-11-01 16:56:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-01 16:56:48 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-11-01 16:56:51 CTS FIX - Firm: GFET | 2015-11-01 16:56:51 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 74.201.6.106 | 2015-11-01 16:56:51 CTS FIX socket (12) | Connected. | 2015-11-01 16:56:51 CTS FIX socket (12) | Starting TLS 1.0 connection. | 2015-11-01 16:56:51 CTS FIX socket (12) | SSL connection established. | 2015-11-01 16:56:51 CTS FIX: Sending the Logon message. | 2015-11-01 16:56:51 CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:52 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:54.57945=1372=A373=1058=Sending Time Accuracy problem10=194 | 2015-11-01 16:56:52 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:52 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20151102-00:53:54.57945=1372=A373=1058=Sending Time Accuracy problem10=194 | 2015-11-01 16:56:52 * CTS FIX: Received a FIX message from an unknown sender. Expected "GFET", but received "". | 2015-11-01 16:56:52 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:54.57958=FIXLogin Time Tag Accuracy Problem - Out of time window10=234 | 2015-11-01 16:56:52 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-11-01 16:56:52 * FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20151102-00:53:54.57958=FIXLogin Time Tag Accuracy Problem - Out of time window10=234 | 2015-11-01 16:56:52 * CTS FIX socket (12) | Closed. No error. | 2015-11-01 16:56:52 CTS FIX socket (12) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-01 16:56:52 CTS FIX socket (12) | SSL has been shut down. | 2015-11-01 16:56:52 CTS FIX socket (12) | SSL object has been freed. SSL state is now disconnected. | 2015-11-01 16:56:52 CTS FIX socket (12) | Shutdown and closed. | 2015-11-01 16:56:52 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2015-11-01 16:56:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-01 16:56:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-01 16:56:52 CTS FIX: DisconnectFIX called. | 2015-11-01 16:56:52 CTS FIX Historical Data: DisconnectFIX called. | 2015-11-01 16:56:52 CTS FIX: Disconnected. | 2015-11-01 16:56:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-01 16:56:52 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-11-01 16:56:55 CTS FIX - Firm: GFET | 2015-11-01 16:56:55 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2015-11-01 16:56:55 |
[2015-11-02 01:50:23] |
Your computer's clock is not set accurately. This is the problem: Local computer UTC time and Server UTC time difference: 178 seconds. | 2015-11-01 16:56:17 Notice: Your computer's clock is off by 178 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2015-11-01 16:56:17 Refer to help topic 38: Http://www.sierrachart.com/index.php?page=doc/helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
