Date/Time: Mon, 06 May 2024 13:46:04 +0000
[User Discussion] - HaDelta
View Count: 2790
[2015-11-01 21:01:21] |
madra - Posts: 109 |
Hello HaDelta is an indicator that is supposed to work well with Heikin Ashi charts. Would it be possible to add this indicator to Sierra Chart studies? I believe that it is free to download. Thank you, Charlie |
[2015-11-01 21:49:56] |
What specifically does it do? Are you referring to applying the Cumulative Delta studies to Heikin-Ashi bars? This is already supported: http://www.sierrachart.com/image.php?l=1446414560798.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-02 08:03:11] |
BataviaTrader - Posts: 63 |
I believe Madra means something like presented on the lower part of this chart: http://www.educofin.com/picts/SPY-10172011.jpg @Madra could you confirm this? Date Time Of Last Edit: 2015-11-02 08:03:45
[2015-11-02 14:49:06] |
Perfect exactly right. Did not know how to include this link Thank you charlie |
[2015-11-03 22:49:57] |
Have not heard from Support as to whether you plan to include HaDelta to Sierra Chart studies
[2015-11-04 06:56:30] |
crazybears - Posts: 314 |
Hi Madra there is a study called HA smoothed -> may be applying some MAV to it gives the same result..? do you have the formula and some examples how to work with HA charts ? i could try to code it |
[2015-11-05 03:55:41] |
http://forums.worden.com/default.aspx?g=posts&t=53875 Hi crazybears, I noticed HA smoothed in the studies but this is not it. HaDelta was written by DanValcu who wrote a book on Heikin Ashi. It is an indicator that was made to work with HA. The forum above discusses HaDelta and seems to have some code. If you have time you could look at that and see if it makes sense. Does MAV stand for moving average? I know so little about code. When you say code it would that mean that it would be available in SC? All the best, Madra |
[2015-11-05 04:43:18] |
Hi yes mav =moving average ok i'll try |
[2015-11-06 01:23:56] |
Thank you Crazybears, looking forward to what you com up with madra |
