Date/Time: Sat, 18 May 2024 18:47:11 +0000
Re: Study/Price Overlay and Containing match
View Count: 829
[2015-11-01 12:12:22] |
ripsdips - Posts: 143 |
If I'm overlaying a larger frame main graph study over a smaller frame main graph, I find that using Containing Match over Nearest Match brings that larger frame study much closer to current price. My question is will that affect the real reading of the larger frame study or not?
[2015-11-01 18:40:49] |
Refer to the documentation here for the Study/Price Overlay study for a description of this input: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s118 And verify it works as you would expect during real-time updating. The answer to the question should be No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
