Date/Time: Sat, 18 May 2024 22:26:39 +0000
Futures Feed
View Count: 887
[2015-10-30 10:19:47] |
User439975 - Posts: 4 |
Hello, I want to have a futures feed with market depth. I know you do not recommend brokers or other services but do you know where and how is it possible to connect Sierra to a futures feed without the need to open a live trading account? I just need the feed as I trade spot FX. Tell me what to do to sort it out please! thanks! |
[2015-10-30 10:33:42] |
Yes you can do this by using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed But you are going to pay substantially in exchange fees. As an alternative you can use the Sierra Chart Real-time and Historical Forex/CFD Data Feed: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-30 10:33:54
[2015-10-30 11:08:09] |
That is substantial. Is there a more cost effective way to get a futures feed on Sierra? Regards |
[2015-10-30 18:08:43] |
Yes if you open a futures trading account with one of the futures trading services. Here is one you can do that with: http://www.infinityfutures.com Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-30 18:09:03
