Date/Time: Mon, 29 Apr 2024 16:50:21 +0000
Connection log stopped showing time differences
View Count: 695
[2015-10-29 16:41:38] |
Willson - Posts: 176 |
The time difference between my computer and the Sierra server was very useful. It is gone now. Can it be found someway? Regards |
[2015-10-29 16:54:35] |
Sierra Chart - Max - Posts: 5597 |
You can find the Time Difference within the Sierra Chart Message Log (Window >> Show/Hide Message Log). Near the top of the log, you should be able to see a line like the following: Local computer UTC time and Server UTC time difference: 0 seconds. | 2015-10-29 16:53:01 Sierra Chart Support Date Time Of Last Edit: 2015-10-29 16:55:11
[2015-10-29 17:31:04] |
Ever since updating to Ver 1309 the The message log does not display when connecting to Sierra/server. I can force it to display using Windows menu as you instructed. But when I view it, the time difference is not displayed. I forced it to display, then disconnected the data-source then reconnected to data-source. I hope that is the proper sequence to trigger the time differences to display. Regards |
[2015-10-29 18:06:25] |
You will only see the time difference at the very top of the Message Log. It displays only once there.
