Date/Time: Sat, 04 May 2024 17:51:59 +0000
How do I set horizontal lines that will appear behind the chart bars?
View Count: 1078
[2013-06-19 02:18:11] |
You need to enable Study Underneath Main Price Graph in the Study Settings: https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingStudiestoaChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-03 14:10:26] |
User228426 - Posts: 14 |
How do I get Tools > Horizontal Line Alt-8 behind candlesticks on chart?
[2015-09-03 17:58:06] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
