Date/Time: Fri, 03 May 2024 12:21:25 +0000
Connection problem
View Count: 660
[2015-10-29 15:47:55] |
User680060 - Posts: 7 |
Hello, would you help me please with connection to DF? I am not sure I am doing everything right. I have AMP account. In Data/Trade Service settings window I chose Servise: AMP/TTNet In "Price Feed Connection Details": >> Server: 12.41.48.53:10501 >> Sender Comp ID: AC(...account number) >> Password: ***** And what may I write to "Accounts"? My AMP account number? And what to field named FFT2 and FFT3 (I have only 1 account)? Thank you! Best regards, Jim PS: Apologize for trivial question, but there is one saying in my country: "lazy mouth is bare disaster" :) Date Time Of Last Edit: 2015-10-29 15:48:32
[2015-10-29 16:13:23] |
Sierra Chart - Max - Posts: 5599 |
AMP has setup your Sierra Chart account to auto-select CQG. So we recommend, you first try to connect using CQG: CQG Trading Platform Service: Setup Instructions If you are not able to connect with CQG, you will need to contact AMP and get the exact login details from them. And confirm how they have setup your account. Your AMP account can be on one of the following Backends: CQG: CQG Trading Platform Service: Setup Instructions Rithmic: Rithmic Trading Platform Service: Setup Instructions or AMP/TTNet: http://www.sierrachart.com/index.php?page=doc/AMPTTNet.php#SetupInstructions Sierra Chart Support Date Time Of Last Edit: 2015-10-29 16:14:54
[2015-10-29 19:32:50] |
These fields need to be left blank: And what to field named FFT2 and FFT3 (I have only 1 account)?
They are for specialized purposes which do not apply to AMP accounts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-29 19:33:11
