Date/Time: Tue, 07 May 2024 22:02:01 +0000
How to turn off an indicators scaling mode
View Count: 670
[2015-10-29 05:43:38] |
User49270 - Posts: 48 |
Hi, I'd like to know how to turn off an indicators scaling mode, for instance when TPO Developing Value Area Lines are on my chart they scale the chart so that all the current value area lines are shown on the chart, sometimes pushing the price bars to the bottom or top of the screen to fit the lines on the screen. I would like to keep it on automatic scale and have the option to have all the lines showing or not. Other platforms I have used in the past have a feature to turn indicator scaling off. Thanks
[2015-10-29 07:25:45] |
This is explained here: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#BasingScalePriceBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
