Date/Time: Fri, 03 May 2024 06:34:37 +0000
IQ Feed will not work with some indicators
View Count: 843
[2015-10-28 23:05:31] |
User31660 - Posts: 20 |
Hi guys, GU, AU, EAUD, and GAUD are not working with my volume by price indicators. Is there a way to fix it. My EU works but those dont. I attached a screeen shot. It looks like price may be the matter. Thanks |
Problems_with_AU.png / V - Attached On 2015-10-28 23:04:49 UTC - Size: 43.34 KB - 271 views |
[2015-10-29 04:37:54] |
The problem is the Tick Size in the Chart >> Chart Settings is not set correctly. Refer to this page for information about that setting: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TickSize We still have yet to add the symbol settings for these particular IQ Feed FXCM symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-29 04:48:24] |
Sir, Will this take a while? I don't know if I should keep my other charting package because of this. |
[2015-10-29 04:57:50] |
No. We will have it done tomorrow.
[2015-10-30 01:30:27] |
The FXCM Forex symbols have all been added now for IQ Feed. Follow the instructions here to Update the symbol settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps You will see them in File >> Find Symbol >> Forex. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-30 04:01:58] |
Thank you sir for your time However below is my log. I can't connect to IQ Feed properly now. It still says connecting connecting... IQFeed | Connecting. | 2015-10-30 03:57:47 IQFeed | Connecting to Admin port 9300 | 2015-10-30 03:57:47 Socket (11) | Connected. | 2015-10-30 03:57:47 IQFeed | Connected to Admin port. | 2015-10-30 03:57:47 AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-10-30 03:57:47 AdminMessage: S,STATS,,,50,5,4,2114,13,2276,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001006.07,1.43,, | 2015-10-30 03:57:47 AdminMessage: S,STATS,,,50,5,4,2115,13,2277,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001006.20,1.55,, | 2015-10-30 03:57:48 AdminMessage: S,STATS,,,50,5,4,2116,13,2278,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001006.33,1.53,, | 2015-10-30 03:57:49 AdminMessage: S,STATS,,,50,5,4,2117,13,2279,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001006.46,1.53,, | 2015-10-30 03:57:51 AdminMessage: S,STATS,,,50,5,4,2118,13,2280,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001006.56,1.53,, | 2015-10-30 03:57:51 AdminMessage: S,STATS,,,50,5,4,2119,13,2281,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001006.69,1.52,, | 2015-10-30 03:57:52 AdminMessage: S,STATS,,,50,5,4,2120,13,2282,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001006.82,1.52,, | 2015-10-30 03:57:53 AdminMessage: S,STATS,,,50,5,4,2121,13,2283,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001006.95,1.52,, | 2015-10-30 03:57:54 AdminMessage: S,STATS,,,50,5,4,2122,13,2284,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001007.08,1.52,, | 2015-10-30 03:57:55 AdminMessage: S,STATS,,,50,5,4,2123,13,2285,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001007.21,1.52,, | 2015-10-30 03:57:56 AdminMessage: S,STATS,,,50,5,4,2124,13,2286,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001007.34,1.52,, | 2015-10-30 03:57:57 AdminMessage: S,STATS,,,50,5,4,2125,13,2287,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001007.47,1.52,, | 2015-10-30 03:57:58 AdminMessage: S,STATS,,,50,5,4,2126,13,2288,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001007.60,1.52,, | 2015-10-30 03:57:59 AdminMessage: S,STATS,,,50,5,4,2127,13,2289,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001007.73,1.52,, | 2015-10-30 03:58:00 AdminMessage: S,STATS,,,50,5,4,2128,13,2290,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001007.87,1.52,, | 2015-10-30 03:58:01 AdminMessage: S,STATS,,,50,5,4,2129,13,2291,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001007.96,1.52,, | 2015-10-30 03:58:02 AdminMessage: S,STATS,,,50,5,4,2130,13,2292,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001008.09,1.52,, | 2015-10-30 03:58:03 AdminMessage: S,STATS,,,50,5,4,2131,13,2293,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001008.22,1.52,, | 2015-10-30 03:58:04 AdminMessage: S,STATS,,,50,5,4,2132,13,2294,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001008.35,1.52,, | 2015-10-30 03:58:05 AdminMessage: S,STATS,,,50,5,4,2133,13,2295,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001008.48,1.52,, | 2015-10-30 03:58:06 AdminMessage: S,STATS,,,50,5,4,2134,13,2296,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001008.61,1.52,, | 2015-10-30 03:58:07 AdminMessage: S,STATS,,,50,5,4,2135,13,2297,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001008.74,1.52,, | 2015-10-30 03:58:08 AdminMessage: S,STATS,,,50,5,4,2136,13,2298,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001008.87,1.52,, | 2015-10-30 03:58:09 AdminMessage: S,STATS,,,50,5,4,2137,13,2299,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001009.00,1.52,, | 2015-10-30 03:58:10 AdminMessage: S,STATS,,,50,5,4,2138,13,2300,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001009.13,1.52,, | 2015-10-30 03:58:11 AdminMessage: S,STATS,,,50,5,4,2139,13,2301,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001009.27,1.52,, | 2015-10-30 03:58:12 AdminMessage: S,STATS,,,50,5,4,2140,13,2302,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001009.40,1.52,, | 2015-10-30 03:58:13 AdminMessage: S,STATS,,,50,5,4,2141,13,2303,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001009.53,1.52,, | 2015-10-30 03:58:14 AdminMessage: S,STATS,,,50,5,4,2142,13,2304,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001009.66,1.52,, | 2015-10-30 03:58:15 AdminMessage: S,STATS,,,50,5,4,2143,13,2305,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001009.79,1.52,, | 2015-10-30 03:58:16 AdminMessage: S,STATS,,,50,5,4,2144,13,2306,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001009.92,1.52,, | 2015-10-30 03:58:17 AdminMessage: S,STATS,,,50,5,4,2145,13,2307,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001010.05,1.52,, | 2015-10-30 03:58:18 AdminMessage: S,STATS,,,50,5,4,2146,13,2308,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001010.18,1.52,, | 2015-10-30 03:58:19 AdminMessage: S,STATS,,,50,5,4,2147,13,2309,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001010.31,1.52,, | 2015-10-30 03:58:20 AdminMessage: S,STATS,,,50,5,4,2148,13,2310,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001010.44,1.52,, | 2015-10-30 03:58:21 AdminMessage: S,STATS,,,50,5,4,2149,13,2311,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001010.57,1.52,, | 2015-10-30 03:58:22 AdminMessage: S,STATS,,,50,5,4,2150,13,2312,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001010.71,1.52,, | 2015-10-30 03:58:23 AdminMessage: S,STATS,,,50,5,4,2151,13,2313,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001010.84,1.52,, | 2015-10-30 03:58:24 AdminMessage: S,STATS,,,50,5,4,2152,13,2314,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001010.97,1.52,, | 2015-10-30 03:58:25 AdminMessage: S,STATS,,,50,5,4,2153,13,2315,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001011.10,1.52,, | 2015-10-30 03:58:26 AdminMessage: S,STATS,,,50,5,4,2154,13,2316,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001011.23,1.52,, | 2015-10-30 03:58:27 AdminMessage: S,STATS,,,50,5,4,2155,13,2317,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001011.36,1.52,, | 2015-10-30 03:58:28 AdminMessage: S,STATS,,,50,5,4,2156,13,2318,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001011.49,1.52,, | 2015-10-30 03:58:29 AdminMessage: S,STATS,,,50,5,4,2157,13,2319,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001011.62,1.52,, | 2015-10-30 03:58:30 AdminMessage: S,STATS,,,50,5,4,2158,13,2320,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001011.75,1.52,, | 2015-10-30 03:58:31 AdminMessage: S,STATS,,,50,5,4,2159,13,2321,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001011.88,1.52,, | 2015-10-30 03:58:32 AdminMessage: S,STATS,,,50,5,4,2160,13,2322,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001012.01,1.52,, | 2015-10-30 03:58:33 AdminMessage: S,STATS,,,50,5,4,2161,13,2323,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001012.14,1.52,, | 2015-10-30 03:58:34 AdminMessage: S,STATS,,,50,5,4,2162,13,2324,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001012.28,1.52,, | 2015-10-30 03:58:35 AdminMessage: S,STATS,,,50,5,4,2163,13,2325,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001012.41,1.52,, | 2015-10-30 03:58:36 AdminMessage: S,STATS,,,50,5,4,2164,13,2326,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001012.54,1.52,, | 2015-10-30 03:58:37 AdminMessage: S,STATS,,,50,5,4,2165,13,2327,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001012.67,1.52,, | 2015-10-30 03:58:38 AdminMessage: S,STATS,,,50,5,4,2166,13,2328,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001012.80,1.52,, | 2015-10-30 03:58:39 AdminMessage: S,STATS,,,50,5,4,2167,13,2329,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001012.93,1.52,, | 2015-10-30 03:58:40 AdminMessage: S,STATS,,,50,5,4,2168,13,2330,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001013.06,1.52,, | 2015-10-30 03:58:41 AdminMessage: S,STATS,,,50,5,4,2169,13,2331,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001013.19,1.52,, | 2015-10-30 03:58:42 AdminMessage: S,STATS,,,50,5,4,2170,13,2332,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001013.32,1.52,, | 2015-10-30 03:58:43 AdminMessage: S,STATS,,,50,5,4,2171,13,2333,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001013.45,1.52,, | 2015-10-30 03:58:44 AdminMessage: S,STATS,,,50,5,4,2172,13,2334,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001013.58,1.52,, | 2015-10-30 03:58:45 AdminMessage: S,STATS,,,50,5,4,2173,13,2335,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001013.71,1.52,, | 2015-10-30 03:58:46 Service connection timed out. Will disconnect and retry. | 2015-10-30 03:58:47 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-10-30 03:58:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-10-30 03:58:47 Socket (11) | Shutdown and closed. | 2015-10-30 03:58:47 IQFeed | Disconnected from Admin port. | 2015-10-30 03:58:47 IQFeed | Fully disconnected. | 2015-10-30 03:58:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-10-30 03:58:47 IQFeed | Connecting. | 2015-10-30 03:58:50 IQFeed | Connecting to Admin port 9300 | 2015-10-30 03:58:50 Socket (13) | Connected. | 2015-10-30 03:58:50 IQFeed | Connected to Admin port. | 2015-10-30 03:58:50 AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-10-30 03:58:50 AdminMessage: S,STATS,,,50,5,4,2177,13,2339,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001014.00,1.43,, | 2015-10-30 03:58:50 AdminMessage: S,STATS,,,50,5,4,2178,13,2340,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001014.13,1.55,, | 2015-10-30 03:58:51 AdminMessage: S,STATS,,,50,5,4,2179,13,2341,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001014.26,1.53,, | 2015-10-30 03:58:52 AdminMessage: S,STATS,,,50,5,4,2180,13,2342,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001014.39,1.53,, | 2015-10-30 03:58:53 AdminMessage: S,STATS,,,50,5,4,2181,13,2343,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001014.52,1.53,, | 2015-10-30 03:58:54 AdminMessage: S,STATS,,,50,5,4,2182,13,2344,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001014.65,1.52,, | 2015-10-30 03:58:55 AdminMessage: S,STATS,,,50,5,4,2183,13,2345,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001014.78,1.52,, | 2015-10-30 03:58:56 AdminMessage: S,STATS,,,50,5,4,2184,13,2346,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001014.91,1.52,, | 2015-10-30 03:58:57 AdminMessage: S,STATS,,,50,5,4,2185,13,2347,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001015.04,1.52,, | 2015-10-30 03:58:58 AdminMessage: S,STATS,,,50,5,4,2186,13,2348,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001015.17,1.52,, | 2015-10-30 03:58:59 AdminMessage: S,STATS,,,50,5,4,2187,13,2349,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001015.30,1.52,, | 2015-10-30 03:59:00 AdminMessage: S,STATS,,,50,5,4,2188,13,2350,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001015.43,1.52,, | 2015-10-30 03:59:01 AdminMessage: S,STATS,,,50,5,4,2189,13,2351,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001015.57,1.52,, | 2015-10-30 03:59:02 AdminMessage: S,STATS,,,50,5,4,2190,13,2352,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001015.70,1.52,, | 2015-10-30 03:59:03 AdminMessage: S,STATS,,,50,5,4,2191,13,2353,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001015.83,1.52,, | 2015-10-30 03:59:04 AdminMessage: S,STATS,,,50,5,4,2192,13,2354,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001015.96,1.52,, | 2015-10-30 03:59:05 AdminMessage: S,STATS,,,50,5,4,2193,13,2355,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001016.05,1.52,, | 2015-10-30 03:59:06 AdminMessage: S,STATS,,,50,5,4,2194,13,2356,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001016.18,1.52,, | 2015-10-30 03:59:07 AdminMessage: S,STATS,,,50,5,4,2195,13,2357,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001016.31,1.52,, | 2015-10-30 03:59:08 AdminMessage: S,STATS,,,50,5,4,2196,13,2358,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001016.44,1.52,, | 2015-10-30 03:59:09 AdminMessage: S,STATS,,,50,5,4,2197,13,2359,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001016.57,1.52,, | 2015-10-30 03:59:10 AdminMessage: S,STATS,,,50,5,4,2198,13,2360,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001016.70,1.52,, | 2015-10-30 03:59:11 AdminMessage: S,STATS,,,50,5,4,2199,13,2361,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001016.83,1.52,, | 2015-10-30 03:59:12 AdminMessage: S,STATS,,,50,5,4,2200,13,2362,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001016.97,1.52,, | 2015-10-30 03:59:13 AdminMessage: S,STATS,,,50,5,4,2201,13,2363,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001017.10,1.52,, | 2015-10-30 03:59:14 AdminMessage: S,STATS,,,50,5,4,2202,13,2364,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001017.23,1.52,, | 2015-10-30 03:59:15 AdminMessage: S,STATS,,,50,5,4,2203,13,2365,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001017.32,1.52,, | 2015-10-30 03:59:16 AdminMessage: S,STATS,,,50,5,4,2204,13,2366,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001017.49,1.52,, | 2015-10-30 03:59:17 AdminMessage: S,STATS,,,50,5,4,2205,13,2367,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001017.62,1.52,, | 2015-10-30 03:59:18 AdminMessage: S,STATS,,,50,5,4,2206,13,2368,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001017.75,1.52,, | 2015-10-30 03:59:19 AdminMessage: S,STATS,,,50,5,4,2207,13,2369,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001017.88,1.52,, | 2015-10-30 03:59:20 AdminMessage: S,STATS,,,50,5,4,2208,13,2370,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001018.01,1.52,, | 2015-10-30 03:59:21 AdminMessage: S,STATS,,,50,5,4,2209,13,2371,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001018.14,1.52,, | 2015-10-30 03:59:22 AdminMessage: S,STATS,,,50,5,4,2210,13,2372,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001018.27,1.52,, | 2015-10-30 03:59:23 AdminMessage: S,STATS,,,50,5,4,2211,13,2373,,,Not Connected,5.1.3.1,448974,91221.01,0.0,,10001018.37,1.52,, | 2015-10-30 03:59:24 |
[2015-10-30 04:17:27] |
The solution to this kind of problem is to completely exit from the IQ Feed software. You will see an icon for it on your Windows Taskbar system tray. Follow step 10 here: DTN IQ Feed Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
