Date/Time: Sun, 05 May 2024 13:50:04 +0000
[User Discussion] - Linear Regression End Channel - limit on 2000 bars
View Count: 1786
[2013-06-18 20:58:09] |
namlem - Posts: 94 |
Hello, I can't set more than 2000 bars for study "Linear Regression End Channel". After I set it, it resets back to 2000. Can it be extended? |
[2013-06-18 22:19:22] |
maxpi - Posts: 175 |
you could make a copy of the source code, raise that upper limit [it is indeed 2000] and compile it to a new study of your own. You could also apply the existing version to a chart with a longer bar interval and obtain essentially the same information. |
[2013-06-19 00:10:56] |
We will increase the limit on it.
[2013-06-23 09:20:10] |
This is awesome! Next release and issue above solved - guys, you are really amazing! This is what I call a perfect support!
[2013-06-26 00:37:08] |
C. Notes - Posts: 129 |
Awesome.... I've been having issues with that one as well... An X bars before adjustment would be pretty awesome too (like the auto trendlines use) |
