Date/Time: Sun, 05 May 2024 13:10:59 +0000
SL and TP orders
View Count: 1223
[2015-10-28 20:26:31] |
User468762 - Posts: 19 |
Let's say I have an ATM strategy with a 10tick SL and a 20tick TP. I use chart trader. If I "buy market" my SL and TP appear instantly at the same time which is fine. However if I use a stop order, I want my SL and TP to appear only when filled. How do I do that? Thank you |
[2015-10-29 07:38:51] |
Yes you can do this. There is a Trade Window menu command for this and it is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#MenuButton The command is Hide Pending Attached Orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
