Date/Time: Sun, 05 May 2024 14:35:42 +0000
Filtering bid ask volume within Numbers Bars Study
View Count: 1313
[2015-10-28 20:43:20] |
User167108 - Posts: 49 |
I think Its possible. Try BId/ASk Volume Text Threshold option in number bar setting to 500 or which ever number you want
[2015-10-29 19:08:25] |
Refer to this section here for Numbers Bars study Inputs: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#InputSettings The input that you need is: Bid/Ask Volume Text Threshold Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
