Date/Time: Sun, 05 May 2024 15:08:19 +0000
No match price
View Count: 679
[2015-10-28 18:59:52] |
User293865 - Posts: 13 |
the price at sc software doesnt match the price at transact platform . please see attached
ESZ5 Delay.jpg / V - Attached On 2015-10-28 18:58:31 UTC - Size: 118.35 KB - 325 views |
[2015-10-28 19:04:21] |
Looks like this probably is due to a data delay. Refer to help topic 4: Http://www.sierrachart.com/index.php?page=doc/helpdetails4.html How often do you see this? The ES has been very active this past hour, so the data feed might be lagging especially when a TCP/IP connection is being used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
