Date/Time: Wed, 08 May 2024 09:08:08 +0000
2 spread sheets
View Count: 679
[2015-10-28 04:02:47] |
toews&kane - Posts: 209 |
Can I have two different spreadsheets running in two different chartbooks simulataneously? And when I add the spreadsheet study in the other chartbook, it actually doesn't bring up a new chartbook but it brings up the already used spreadsheet in the other chartbook. How can I make a new spreadsheet? Cheers |
[2015-10-28 04:18:32] |
Yes. This will work. You need to specify a different Spreadsheet Name in the Spreadsheet Study Settings. Or change the Chart Data Output Sheet Number study Input to a different Sheet than the ones used by the other Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
