Date/Time: Tue, 07 May 2024 13:04:25 +0000
fib retracement tool
View Count: 1433
[2015-10-27 21:55:24] |
Crtfyd - Posts: 277 |
vs 1282 Is there a setting to change to be able to see the levels constantly(%, and price) on the retracement tool? When I use the tool on a zoomed out chart, then zoom in, the levels (whether right or left) disappear and the only way to see the level amounts (and not just the line) is to zoom out every time. This becomes arduous when checking several times. |
[2015-10-27 22:01:20] |
Post an image of the chart where you can see all of the levels by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image It is also important to use the correct terminology. Are you referring to the "Price Retracement" tool? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-27 22:01:58
[2015-10-28 02:54:33] |
Sorry, yes I mean the Price retracement tool. 1st pic I can see levels on right (I highlighted them). 2nd picture after zoom I would hope they stay on right (adjust to stay seen) if you zoom in past the drawing level. http://www.sierrachart.com/image.php?l=1446000668710.png http://www.sierrachart.com/image.php?l=1446000857316.png |
[2015-10-29 04:26:15] |
Right-click on the Price Retracement drawing and select Chart Drawing Properties: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartDrawingProperties Enable Options >> Extend Right. That will solve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
